Displays the log configuration for the specified filter.
| filter_name | Specifies the filter to display. |
If no options are specified, the command displays the configuration for all filters.
This command displays the configuration for filters.
The following command displays the configuration for the filter, myFilter:
show log configuration filter myFilter
The following is sample output from this command:
Log Filter Name: myFilter I/ Severity E Comp. Sub-comp. Condition CEWNISVD - ------- ----------- ----------------------- -------- I STP -------- I aaa -------- Include/Exclude: I - Include, E - Exclude Component Unreg: * - Component/Subcomponent is not currently registered Severity Values: C - Critical, E - Error, W - Warning, N - Notice, I - Info * - Pre-assigned severities in effect for specified component Debug Severity : S - Debug-Summary, V - Debug-Verbose, D - Debug-Data + - Debug Severities, but log debug-mode not enabled If Match parameters present: Parameter Flags: S - Source, D - Destination, (as applicable) I - Ingress, E - Egress, B - BGP Parameter Types: Port - Physical Port list, Slot - Physical Slot # MAC - MAC address, IP - IP Address/netmask, Mask - Netmask VID - Virtual LAN ID (tag), VLAN - Virtual LAN name L4 - Layer-4 Port #, Num - Number, Str - String Nbr - Neighbor, Rtr - Routerid, EAPS - EAPS Domain Proc - Process Name Strict Match : Y - every match parameter entered must be present in the event N - match parameters need not be present in the event
